A small portion of my crawl space still had dirt along 3 feet of the wall on the east and west walls. The crawl space is enclosed by block on all walls but three of them are resting on a solid limestone outcropping. They bridged the original foundation to the rock with a lintel so that's where the dirt is still coming in and allowing a good deal of moisture in there. The moisture is controlled by a dehumidifier but there is a radon issue so we had the areas blocked and the plan is in process. While they dug to put in the blocks the dirt kept falling in and caused an undercutting along the exterior of the house at both ends. Well, One of them finally caved in and I'm wondening what I should use for fill, keeping in mind that there is so much moisture there that the new block wall is wet clear thru the parging only when we have hard rain. And no, there are no gutters nearby. I'm think more of a wet weather spring.
So, what do I fill these two cavities with to keep the moisture at bay?
but I guess that it could be done.
