Anyone here have any experiences (good or bad) installing hardwood floors (either solid or engineered) on a concrete slab (fully cured, above grade)? LOML's newly-acquired house is going to need new flooring throughout and she's gung-ho about real wood floors. Laminate isn't an option (it's an older home and we'd like to keep as much "old-house" character as we can, so plastic flooring isn't too desirable), so I'm looking at all the options in engineered and solid hardwood, trying to find a good solution.
The traditional, "nail down plywood or battens and nail the floor to those" method would raise the floor something like 1.5", which seems like a poor solution. There are systems from Junckers and others that use thin steel rails attached to the floor and clip the solid planks to those. Clever, but expensive.
I'm leaning toward a glue-down or floating engineered floor, but most I've seen either look cheap or have a very thin top veneer, making me wonder about durability. Ideally, I'd like to do the install myself (I've installed glue-down parquet floors and click-together engineered cork, as well as refinished several traditional hardwood floors, so I think I'm pretty aware of what I'm getting into). Any product recommendations or things to watch out for as I shop around?
Also, what about bamboo? I've seen some really nice-looking solid bamboo planks, and have been told you can glue these at the tongue-and-groove to make a floating floor. Has anyone here done this?
