We just installed a new Delta kitchen faucet. It's the single handle pullout type. It's also a center mount style which means that there is only one hole through the counter top through which both supply lines run. Installation was quite easy except for fitting my overweight body under the sink. Now that it's installed we can't get the spout to rotate from side to side to direct the water flow in the sink. You have to pull out the end of the faucet to direct the water flow. Delta online help tells me that you should be able to rotate the faucet and that maybe an o ring was out of place on the faucet stem. I took the entire faucet apart and could find no problems with o ring or any other parts.
Has anyone else run in to this and what did you do about it?
Thanks in advance for help!!!
