I have all my ducks in a row for the front steps tiling project which I'm starting this weekend, so I'm planning the next project.
I have a small side yard where my shed/shop is located. My shed is only 10' by 12' and really pretty small, limiting the projects I can do. Right now, I can barely go in there without tripping on something.
I want to build a floating deck around the shed to allow me to move some of the tools outside and give me more room.
Since the yard slopes towards the street (we're on a corner lot), I'm thinking of dumping gravel on the yard to get a level base. The floating deck is just an unanchored deck with pressure treated wood for the base and probably cedar or redwood for the planks.
I have a pretty good idea on how to build the deck, but I'm not sure about the gravel part of it. Should I put sand on it, too? Is a floating deck even a good idea? My original plan was to use concrete anchors, but I'll still have to level out the ground. Then I thought I can put pavers on top of the gravel/sand instead, and finally settled with a floating deck because it's the easiest to do. I think. I've never done any of these before so I'm laboring under extreme ignorance.
It would be nice to have an even, semi-permanent/permanent surface to work on though. I would really appreciate any input/recommendations.
