Lowe's Pewter Kitchen Panel
  • supper shaun
    • Dec 2006
    • 85
    Has anyone used this or had any experience installing it? Looks fairly easy, but wondering about cutting panels in half. Sure is shiny!
    http://lowes.shoplocal.com/lowes/def...3dLowes-071222
  • rcp612
    • 358
    • Mount Vernon, OH, USA.
    • Bosch 4100-09
    I used that exact design for a backsplash on two walls of our kitchen. Very easy to use, very easy to cut, (razor knife), and I applied it with Power Grab. Just make sure to orient all cuts from the same end. The opposite ends ARE different and can fool you. Been there, Done that!
    The edge molding, though very, VERY hard to miter will add a nice finishing touch to any open ends.
      that is 18$ per 18x24" panel? Or are the panels smaller and get enough to cover 18x24"? Asking because I am thinking about that for a backsplash and I know the area is not 18" high so do not want a lot of waste.
      • frumper64
        • 376
        • Garland, Tx, USA.
        Backsplash
        If this is the same stuff I have seen in their stores, the sheets are 18 by 24 with multiple patterns embossed in each one. I'm not sure how they would work out for a backsplash though, since they seemed like pretty thin lightweight plastic and would stand a good change of getting damaged as a backsplash.
        64sedan_at_gmail.com
