Onward to the next project which was installing a prehung steel door. It's actually the first time I've ever hung a door either interior or exterior.
It's in there temporarily and everything is plumb and level but I'm stuck on two things.
First: The reveal on the HINGE side between the slab and the jamb isn't equal from top to bottom. It's about 1/8 from the top almost to the bottom hinge, but then cuts down to about 1/16 from the bottom hinge to the sill. (ps- the revel on the hinge side is double this amount but even all the way)
Wouldn't the hinge side reveal be 'fixed' by hinges themselves? If I push left or right on the jamb won't the door just move with it? Or am I just too tired to think straight. (no pun intended)
Second, the door is plumb side to side and front to back, but the wall isn't from front to back. This is giving me about a 3/16 difference front to back from the top of the door to the bottom. Seemed like a good idea at the time, but I can see that trimming this thing both inside and outside is gonna be a nightmare if I can even figure it out. Should I forget the front to back and just install it flush with the wall?
Seemed like such a simple project.
