My basement has concrete walls with foil faced fiberglass insulation. I want to
finish off a section with stud walls and drywall. The problem is that section has
the electrical panel mounted to some wood on the concrete block wall. Is it
code compliant to build around it or put it in a "closet" so I can access it later?
Thanks, Paul
Thanks, Paul
