Is it OK to just paint a ceiling with primer and not put "regular" paint over it?
Here is the story:
I am semi-finishing part of my old basement (built in 1923) for a family room. Floor to joists is just 82 inches, so I am painting the joists and calling that the ceiling.
It is a maze of wiring and pipes, and the joists are VERY rough textured compared to today's lumber, so the only option for painting is to spray it. I knew it would be a nightmare, but it has exceeded my expectations in that regard.
I used oil-based primer first. It sprayed OK but nearly killed me because there is just one small window in the room. I am pretty sure I lost 20% of my brain cells in the 30 minutes I was able to stand it.
So, I switched to latex primer. After much anguish I finally came to the conclusion you can spray latex from the Wagner Power Painter's attached cup, but not from the can like I did with the oil-based - even after thinning the latex to the point of uselessness.
Spraying out of the cup works fine with the unthinned latex, but I am getting some bleed-through from the ancient wood. Where I used the oil-based, there is no bleed-through.
I am hoping that one more coat of primer will seal it and stop the bleed-through. I can't tell you how tired I am of spraying. I planned to have the ceiling bright white anyway, so the idea of doing one more coat of primer and leaving it like that is growing on me.
So - is that a problem? Is there anything inherent to primer that requires it be top-coated?
Here is the story:
