So I went to HD to pick up some stucco mix of which I was under the impression that I just need a bag of "stucco".
After looking at my options it appears that for the project I'm doing (re stuccoing newly installed window trim and its surround) that I need more than just stucco, specifically some kind of base coat.
Right now I have 15lb felt paper over studs (my house wasn't built with plywood sheathing) and I will be attaching a wire mesh to that (non self furring, that HD carries):
I picked up some mortar that said it could be used for one coat stucco and I also picked up some stucco finish coat.
Am I on the right track?
Here is the window trim I am talking about which will also be covered in felt and diamond mesh.
