I poured some self leveling compound last night. Now I have a different problem. I have worked with self leveling compound before, several times, with no problem. For some reason the stuff last night turned out really thick ( I had even added 30% more water as I mixed it because it looked to thick). Don't know what went wrong, I read the instruction and followed the directions.
When I was pouring it in/on I thought it looked too thick, but thought it was just me, and it would level itself out. I smoothed it out the best I could, feathered it out like I have done in the past. There were little ridges and bumps left that I figured it would settle / level itself out, like they did all the other times, NOT!!!
I have two areas first area is in my basement bathroom, right in front of the the sink. It looks way to rough to put self stick vinyl squares down. The other area is in my basement office right where the office chair rolls around. Filled in a hole that kept getting bigger from the chair wheels.
Is there a way to smooth out the bumps and ridges???? Or would I need to try and chip the whole thing out, and redo!! The bathroom area is poured on concrete & previous self leveling compound (had to fix a bad spot that broke away). The area is about 2' X 1'. The office hole was about 6" across in concrete.
Would this method kick up a lot of concrete dust?
