Okay, Mine went Sproing, so I think I need a new one or two. So how do I go about replacing these things.
I've heard they can be very dangerous if you are not careful in removing them (as in they have a LOT of pent up energy just waiting for the careless fool).
Removal of the one should be safe. It isn't tentioned anymore. The other I'll have to figure out before I'll even attempt. These are long 4" diameter springs that are laid out horizontally above the garage door. They tension a pully on either side that has a cable attached to the door itself.
How do I safely remove this one, and what do I replace it with?
This is a double wide door so not having the springs is not an option. Disconnected from the opener I can't lift the door with the one good spring. The opener has to be helped and my wife can't.
Black wallnut
