David,
I think you might have misunderstood him. This might be working for you, but it is not proper. If the wire is a neutral, it should NOT be flagged (that is what the black tape is doing) as being hot.
If you are using a "white" wire as a switching wire then YES it should be flagged. For example if the hot came into the light fixture first. Then you send the hot to the switch down the black wire, and the "white" flagged as hot back to the light to turn it on.
In this case the HOT is starting at the switch. So you are send a black that may or may not be hot, a white that is neutral, and I hope a ground. If the white is flagged as black then I would see that and think it's 220 coming to the light, 1 leg on the black, 1 leg on the flagged white.
