Is it ok to use OSB under the laminate flooring or should i be using mdf?
I am going to be installing laminate flooring and tile in my house. Currently its carpet and vinyl.
I want to ensure where it transitions the heights are close to the same. Im guessing i have 1/4 laminate under the vinyl and figured i would be removing that (12 yrs old).
Im planning on installing hardibacker (1/2") under the tile raising that area. My question is on the area that will be laminate flooring can i use OSB as the subfloor or should it be MDF? The base is 1 1/8 cant remember if its OSB or plywood.
