This has probably been done to death, but which side up w/ miter saw, w/ table saw, & w/ circular saw. Thanks, Joe
Cutting Laminate Floor
Tags: None
FWIW, I tried it both ways on my CMS and with the proper blade I can't see any difference in the quality of the cut ... YMMV"Experience: that most brutal of teachers. But you learn, my God do you learn". by C.S. LewisComment
Without getting too technical, I always look at which way the blade turns-which dictates which side of the wood has the splinters after cutting!RuffSawn
Nothin' smells better than fresh sawdust!Comment
The way to remember it is you always want the teeth turning into the good side - any chipout will occur when the blade exits the work piece. I'm with Jscook on the quality/sharpness of the blade. I have one blade that will chip out and another better one where it does not matter.David
In general (don't know if it matter for laminate flooring)
Circ saw - Good side face down
Table saw - Good side face up
Miter Saw - Good side face up.
As previosly stated, you want the teeth to exit on the bad sideLast edited by Stormbringer; 01-23-2007, 08:48 PM.Comment
To add - if you are going to put in on the floor, and not use for something else - like a countertop - it really makes no difference how you cut it. Cut edges are all going to be at the wall, and covered by baseboard/quarter-round.Comment
head like a sieve most days
