I'm in the early planning stages of a project for next spring.
I need to make several cast concrete slabs about 51" x 11" x 3.5"
These will be poured and cured, then removed from the forms and placed.
I would like to add some detail along one long edge and one short edge on each slab. Basically, I'd like to make the edges look like rough cut stone.
I'm envisioning using some existing rough-cut stone I have on hand to make an impression in something that is initially soft but will then harden. This would then be placed in the wood form.
Would Bondo work for this? I'm thinking the concrete would adhere to it...? Could I coat it with oil/release agent? I'd like to be able to reuse this "mold" a couple of times.
Any other ideas? I don't really want to get into the pro-style rubber mold materials...but maybe that's the way to go?
