Hello,
I recently took down the rubber molding that was around my vinyl floor in my kitchen ( I was stripping wallpaper and repainting). That part being done , I want to put down new base molding. The problem is that the edge of the flooring has curled up over the years and the base molding is lifted up a little and not flush with the floor.
Any Suggestions? it's 17' long and I am using two pieces of molding. found an answer about using an iron and heating up the flooring - how long will it stay pliable though? Long enough for me to lay down the base molding? I was also thinking of running a small rabbet down the back of the molding.
Thanks in advance,
Jeff
Thanks in advance,
Jeff
