Hey folks... LOML and I are currently looking into converting our home from oil to gas heat. It's an older home, roughly 2000sq feet, with hot water baseboard heat. We've also got 1 1/2 baths, but may at some point expand the 1/2 to a full. Our current boiler supplies all hot water and heat for the house - we don't have a separate hot water heater, and would like to keep it that way.
Now, I've got a few friends that work in the service department for a local gas company, so I should have the labor piece of the conversion pretty well in hand.
But what should I expect to spend on the actual equipment? So far, I've only been to the Borg - not planning to buy equipment there, just hoping for a ballpark guesstimate. As they only had a single gas boiler there, there just wasn't enough to get a good estimate (and the folks I talked to there were almost completely clueless about the specs of the thing to boot!).
Our Oil boiler was replaced by the previous owner of the home - it's probably only 5-10 years old, and the system is up to code. All I'd be looking to do is a straight swap (if that's even realistic) of one furnace for the other.
Any guesstimates and/or suggestions on what type of equipment I should be looking at? This is definitely something I don't mind spending a few extra bucks on if it'll get me something more efficient and reliable. Thanks in advance!
