Staining Pressure Treated Wood
  • jhart
    • 1715
    Added an addition to an existing deck over last weekend using pressure treated wood. How long are you suppose to wait for the wood to dry out to put a stain/preservative on it? I have heard between 2-4 weeks??
  • Copper
    • 343
    • Madison, WI.
    I think it depends on the kind of preservative treatment. This is from the Wood Handbook:
    In general, preservatives formulated
    in oil will not accept a finish. In some cases, oil-based
    semitransparent penetrating stains can be used on these
    products, but only after the preservative-treated wood has
    weathered for 1 to 2 years, depending on exposure.
    The only preservative-treated woods that should be painted
    or stained immediately after treatment and without further
    exposure are the waterborne preservative treatments (such as
    CCA-treated wood). Since wood treated with these preservatives
    is often used for residential structures, it needs to be
    finished not only for esthetic reasons, but also to protect it
    from weathering. Many manufacturers of chemicals for treating
    wood with waterborne preservatives include a waterrepellent
    treatment to give the treated wood better resistance
    to weathering, particularly checking and splitting. Even if the
    wood was treated with water repellent by the manufacturer, it
    should be maintained with a finish to extend its service life.
    Wood used in aboveground applications that has been properly
    treated with preservative is usually replaced because of
    weathering, not decay.
    - Dennis
    "If your mind goes blank, don't forget to turn off the sound." --Red Green
    and yes, it's a potato.
      2-4 4 weeks is correct, depending on weather and where you live. In NC in July, 2 weeks would be ok. 4 weeks is even better.
      • jAngiel
        • Oct 2003
        • 561
        I would say you need to read the lable for the stain that you want to use. When I built the fort for the kids I used pressure treated wood and bought Behr opaque exterior stain and it said it could even go on wet wood so as soon as finished building it, I stained it. I haven't had any problems with it at all, and it had to put up with kids and extreme heat. No flaking no peeling and still as bright and colorful as when I stained it. I was actually surprised at how the colors are holding out.
        I'm sure you're not going to use the same bright colors on a deck but the thought is to read the can, if it says it's okay to use on wet wood the go ahead and use it. If it's not an opaque stain then you would want to wait a few weeks for the green color to go away prior to staining even if the can says it's okay for wet wood.
        Just my thoughts...
        James
        • jhart
          • 1715
          Well, the old adage "when all else fails, read the instructions" sure holds true here. Tells me right on the can that can be used right away on pressure treated wood, or wait and do it later. Using Olympic semi transparent oil based. Had used it on the previous part of the deck, and of course, didn't think to read the instructions before I posted.
          Thanks for the reply's
