Flooring Questions
  • mnphats
    • 31
    • Victoria, MN.
    Flooring Questions
    I am going to be replacing the flooring on the main level, pulling up carpeting and linoleum. I would like to put down carpeting, hardwood and tile.
    From the basement, it looks like there is 23/32 OSB subfloor, and I don't know if there is an underlayment.
    In a perfect world, the new flooring will all be level.
    1. If the tiling is 3/8" and the cement board is 1/2", how much will the 2 layers of morter (below the cement board, and below tiles) add to my height?
    2. If I decide to hardwood and carpet only, can I put 3/4 hardwood over the OSB, or would I need to add an additional plywood layer?
    3. How do I determine how high to build up the carpet section? Do I want the finished flooring flush with the bottom of the carpet nap?
    Thanks for the advice.
    "Live as if you were to die tomorrow. Learn as if you were to live forever."
    -Mahatma Gandhi
  • newbie2wood
    • Apr 2004
    • 453
    • NJ, USA.
    1. The added height is minimal. I would say 1/8".
    2. You can install over OSB but put down an underlayment.
    3. Its easier to install a transition threshold. Otherwise, you are looking at building up the entire carpet section.
    ________
    DOUBLEMIGHTYX
    • agent511
      • Jun 2005
      • 257
      • Philadelphia
      • TS3650
      Try googling 'flooring forum'. you will find lots of forums like this that are manned by flooring experts, and hopefully you can get more advice then you will find here.
      darksider
