Fence Install?
  • SHADOWFOX
    • 1232
    • IL, USA.
    • DELTA 36-675
    Fence Install?
    Hi Y'all
    Just moved into a new house and the neighbors in the back and on our right side already has a fence so only one side of the property has no fence. When installing a fence how much distance inside of your propertly line can you put up the fence? Is it a foot or more? Greatly appreciate any info.
    Thanks,
    Chris
  • 430752
    • 855
    • Northern NJ, USA.
    check with town
    In my area, fence placement is subject to code where they don't want it certain distances from property line. For example, if I remember correctly, they don't want the fence within 2 feet of your front facing property line. And it can't be more than 3 or 4 feet high. For side and back lines, again if I remember correctly, fences are okay on the property line, unless a structure is within 10 feet, then they want the fence at 10 feet from any habital structure. If you have a corner lot, then the front fence requirements on the one side facing the corner.
    I guess for the front its about appearances, side and back I guess is about not giving your neighbor a blackout.
    so, check with town, you may be lucky and live in an area where no code on fences.
    curt j.
    A Man is incomplete until he gets married ... then he's FINISHED!!!
    • newbie2wood
      • Apr 2004
      • 453
      • NJ, USA.
      It depends on the code if you are intending to apply for a permit. Otherwise, its pretty much up to you but don't make the violation too obvious.
      ________
      Live Sex Webshows
