All,
I have been in the process of replacing all of the base / casing molding in my house with painted (white) wood molding. Once I have completed a room, I go around to all of the gaps in the casing miter joints and base scarf / cope joints and fill in with "Elmer's Professional Wood Filler", then sand once dry and touch up with paint. The problem is that several weeks later the filler in these gaps is starting to crack. I asked at HD, and the guy there did not know of what else to try. I thought about caulk, but that tends to not end up flat on the joint and cannot be sanded. There must be some product or technique I am missing here. Any advice would be appreciated.
Regards,
Pete
Buckeye95
Regards,
Pete
Buckeye95
