Can a 2" line handle a commode?
  • lago
    • 473
    • Lago Vista, TX.
    I want to add a 1/2 bath(commode and lavatory) in a store room next to the garage. All I have accessible is a 2" drain pipe that is used by the dishwasher & sink.
    Just wondering if it could handle a commode, water only, no paper or solids?
    I think I have seen where they have 3" commode fittings.
    Thanks
    Ken
  • 91FE
    • 303
    • Philadelphia (actually Souderton), PA.
    I wouldn't do it. How are you going to guarantee the no solids and paper edict? Just pee in the sink
    I like Wagoneers too. Hey...they've got wood
    • billwmeyer
      • 1868
      • Weir, Ks, USA.
      A urinal yes, a commode no. But hey, they can't yell at you for leaving the seat up that way.
      • lkazista
        • 330
        • Nazareth, PA, USA.
        Nooooooooooooooooooooooooooooo!!!!!
        • kramer katt
          • 375
          • SO CAL, USA
          • BT3100 and Craftsman 100
          I agree, good practice and plumbing codes preclude this.
          However there are a couple specialized WC's that can be set up on a 2'' line.
          They have built in grinders and pumps or other mechanisms to output liquid only. They are not cheap but can be used when there is no other option.
          kk
          --Albert Einstein
          • lago
            • 473
            • Lago Vista, TX.
            Thanks.... guess I will just have to plant some bigger trees.
            • scorrpio
              • 1566
              • Wayne, NJ, USA.
              If I remember it right, the closet needs at least a 3" drain if the distance to main stack is less than 2ft, and 4" is it's more than that. And the drain must have at least 1/8" slope (or was it 1/4"?) per 1ft of length.
              You'll have to either make do with a urinal, or get a macerating toilet like SANIPLUS from Saniflo, which needs no more than a 3/4" pipe running to main stack - but those cost in $700-800 range.
