Well, as the subject suggests, I've got a section of ceiling above my staircase that's cracking in several spots. I can't tell how deep the cracks are, but they all appear to be hairline cracks and no loose material is coming away from them.
To complicate matters, the ceiling is entirely at the second floor ceiling height, with the stairs dropping away below it. I can reach the ceiling using a carefully placed ladder, but want to avoid as much work up there as I can.
So, is there any general advice or rules of thumb when dealing with a ceiling in this condition? The cracks are such that I think a coat or two of ceiling paint would sufficiently cover them up. Is this advisable, or should I skim coat over the cracks (I'd probably just scrape / sand away the texture, tape and mud, then reapply texture) before painting?
I've considered slapping up some 1/4 or 3/8 drywall as a new ceiling surface, but I'd run into trouble with moulding and door-fram clearance at the top of the staircase.
Thanks in advance!
Thanks in advance!
