For some reason, I get the feeling that Jim should have elaborated a bit on his suggestion. [8D]
I'm not sure what you would tell the long arm reps, but I'd sure like to hear what you come up with.
I second all the comments, Pat. Welcome aboard. Nice group of people here, always willing to listen, help amd respond quickly to your problems. Don't forget to post some pictures of your work as you get a chance.
Chuck C
If the skipper heard you call that deck a floor he would throw you through that little round window
You can't be a real country unless you have a beer and an airline - it helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. -- Frank Zappa
Everybody says that finishing means staining and sealing but is there a law they have to be done together? Stain should not interfere with glue, so what if -
stain before the assemply and seal after. The catch is to watch for any glue squeezed during the assemply process - it may ruin the look.
And I am joining the crowd welcoming you.
Congratulations on the acquisition of your BT3100 and welcome to the "family".
One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the preceeding proceedure, so you MUST keep them in sequence.
Regardless of what you've read or others have told you, NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes. The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
entire saw. Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/ The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site). One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea. One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
George
