Gluing Mortise and Tenon Joints
  • sawdustman
    • Jan 2005
    • 49
    • Pittsburgh, PA.
    I just finished making the pieces for a gate to keep our 8 month old off of the stairs. The frame is now ready for gluing.
    What's the best way, or is there a certain technique, to gluing M&T joints? This is the first time I've made them.
    Thanks.
  • Tom Miller
    • 2507
    • Twin Cities, MN
    Brain dump:
    1. Make the mortise deeper than the tenon so excess glue has somewhere to go without completely filling the gap -- you don't want to have to fight this hydraulic pressure.
    2. You only need to apply glue to the 4 cheeks of the tenon, and the 4 sides of the mortice. This is where the glue bond counts. No need to see squeeze-out.
    3. Check your dry fit. The fit should be snug, but you should be able to put the pieces all the way together by hand, roughly speaking. When you apply glue, the pieces will swell enough that you'll need a clamp to fully seat the joint.
    You might find it useful to do a "wet fit dry run" which means to coat the parts with water as you would with glue, and see how the fit is affected by swelling.
    I have not yet glued an M&T joint, or a dado joint, where I felt the parts were not at least a little on the "too tight" side.
    Regards,
    Little bit of brain didn't make the dump: a slight chamfer on the leading edges of the tenon make for quicker insertion when the glue clock is ticking.
      When you put glue on the tenon, only put it on the half furthest from the shoulder. Inserting it into the mortise will spread the glue along the tenon back towards the shoulder and you won't get squeeze out. Likewaise, put glue down into the mortise and not near the top the same reason.
      • sweensdv
        • 2873
        • WI
        • Baileigh TS-1040P-50
        After you do your dry fit, don't take the joint apart by rocking the two pieces back and forth. Take a mallet and a piece of scrap and knock them apart.
          Use a brush to apply the glue.
