hi. I am brand new, working on my first project, a coffee table, made with glass and bubinga.
I need to cut large notches, about 2" wide and two inches high, into the middle of the bottom of the long ends.
I don't have a Dado blade, nor is my BTS15 table supposed to be able to use one.
I was thinking of standing the piece up - it is about 2 feet tall, 10" wide, 8/4 thickness, using the SMT and making the fence bigger with some clamped-on MDF, then clamping the piece to the extended fence, and just make many repeated passes, nibbling away till i get the full 2" width. Hopefully the construct will be stable enough.
Any better ideas?
Also what can I finish with - I was going to use Tung ioil, like they usuallyuse on DIY. But I see many people here use poly...
Any better ideas?
