Joinery for crown molding box?
    Has anyone made a crown molding box? I was wondering what kind of joinery would be used. Is there enough meat in the molding for a biscuit? For instance.
    Thanks,
  • WoodPirate
    • Jan 2005
    • 312
    • Jacksonville, FL, USA.
    Keith,
    I'd think 45's glued up and maybe some exotic splines for strength would be plenty. That Titebond is some pretty amazing stuff!
    --==<< Steve >>==--
    Praise the Lord and pass the ammunition.
    • don_hart
      • 1005
      • Ledayrd, CT, USA.
      I would agree with Keith. On you basic crown molding box simply gluing up the miter joints should provide you with plenty of strength.
      Don Hart
      You live and learn. At any rate you live.
      www.hartwoodcrafts.com
      • bfrikken
        • 727
        • Michigan, USA.
        • BT-3100
        Couldn't you also 45 a biscuit in there if you have enough depth and want to ensure the extra glue surface area?
          bfrikken, that's pretty much the question that I asked.
          • bfrikken
            • 727
            • Michigan, USA.
            • BT-3100
            quote:bfrikken, that's pretty much the question that I asked
            Um, well, then yes
            • Jim-Iowa
              • Mar 2005
              • 769
              • Colfax, Iowa, USA.
              An interesting question. I agree that a 45 glued would probably hold fine. A Coped joint would offer good glue area.
              Contrasting colored splines might be interesting?
              Th only Biscuit Jointer I have is the Royobi Mini and know that would work fine. I have built cabinet door casings as small as 1 1/4" and used them for that. Not as sure about full size Biscuits?
              Now what I have been kicking around, and have not yet tried is through Dovetails? I`ll have to try that on scrap before I reccomend it.
              Sanity is just a one trick pony. Being a bit Crazy is a wide open field of opportunity!
              • mmcduffie
                • 146
                • Des Moines, Washington.
                http://www.compoundmiter.com/index.html
                has the answers to these and many other crown molding questions.
                I picked up the book but not the "True angle" at BORG awhile back.
                Michael
