Best material for bottom of homemade push pad
  • lcm1947
    • 1490
    • Austin, Texas
    • BT 3100-1
    Seems like this is a worthwhile item to have or maybe two of them so was wondering what you guys think would be the best material to use on the bottom of a homemade one. The only thing I can think of is the rubber type stuff router users use to route stuff on when they don't want to clamp the project down with clamps. What all have you guys used or heard about.
  • dlminehart
    • 1829
    • San Jose, CA, USA.
    I use a rubber-bottomed masonry float. Already has wooden handle, 4x10 base, with 0.5" rubber pad on the bottom. Cost about $5 at a hardward store. Works great. Looks like this:
    - David
    • sweensdv
      • 2872
      • WI
      • Baileigh TS-1040P-50
      The router pad material would be fine you can buy rubber shelf liner for less money and it will work just as well. You could also just buy push blocks for not a lot of money. I think I paid about $3 for mine.
        old mouse pads.
          I picked up some peel and stick 1/8" foam pads at a yard sale to put on the DC ports of some of my tools. Thanks for the idea for the rest of them.
            quote:Originally posted by Ken Massingale
            old mouse pads.
            That's bloody brilliant! Always wondered what those things might be good for, other than oversized coasters.
            • MikeMcCoy
              • Nov 2004
              • 790
              • Moncks Corner, SC, USA.
              • Delta Contractor Saw
              The spray adhesive works well with the mouse pads.
              • RickLab
                • 318
                • Plano, TX, USA.
                Old mouse pads work great - I made my own version of a gripper with one.
                • Tom Miller
                  • 2507
                  • Twin Cities, MN
                  I used adhesive-backed foam weatherstrip for my push pads. It's about 1" wide and 1/8" thick.
                  For my push shoe I used adhesive-backed rubbery anti-slip stair tread stuff (ask for it by name! [)]).
                  Regards,
                  • lcm1947
                    • 1490
                    • Austin, Texas
                    • BT 3100-1
                    I knew you guys would come up with something. I just couldn't think of anything except, well actually I still can't think of anything so thanks for the help. Those mouse pads sound great as we have several of them at work just sitting there. Great idea thanks Ken for that one and the rest of you too. Spray adhesive? Hmmm, might have to check that out too thanks Mike.
                    • Brian G
                      • Jun 2003
                      • 993
                      • Bloomington, Minnesota.
                      • G0899
                      I'm getting here late, but the non-slip rubber stuff used under throw rugs works great, too. You can find it in the "throw rug" area at HD.
                      Brian
                      • lcm1947
                        • 1490
                        • Austin, Texas
                        • BT 3100-1
                        Well, it was settled for me today when I went over to Woodcrafters. They had the orange plastic ones that I'm sure everybody has seen one time or another for $4.00 apiece and I thought Hmmmm, for 4 bucks what the heck. I am now the proud owner, well maybe not proud but I am the owner of two of them. But next time when I don't have a hundred other things I need to do or build I will make my own and remember these answers. Thanks everybody.
                          Lee, those are excellent push blocks. Unless I need a large one I don't waste my shop time making them, better things to do, IMHO.
                          ken
                          • lcm1947
                            • 1490
                            • Austin, Texas
                            • BT 3100-1
                            Yeah Ken I agree. I've got way to much other stuff to do but it's good to know that if I ever do need to make one I'll know what bottom material to use. Thanks for the reply.
