I'm making the router fence featured on Wood magazine's cover recently. The faces of the fence are adjustable left and right, via slots on the back. To make the slots, they recommend using either a scroll saw or . . . a table-mounted router with a fence! Hello!
Not having a scroll saw, I used the edge guide that came with the router, on slots roughed in with an appropriately sized bit in my drill press. Tightened the edge guide down with the knurled screws. And found that strenuous hand-tightening was inadequate; vibration loosened the screws about halfway through the 2" slot cutting. Wayward slot.
Also, even when fixed, the edge guide only prevents the bit from moving away from the edge. Although the plywood was only 1/2" thick, and the bulk of the wood was drilled out, perhaps I should have eaten away 1/8" at a time. Anyway, the bit would sometimes grab on the rough inside of the drilled slot and jiggle a little toward the edge.
Result: depressingly funky slots, on outlandishly expensive ($4/sq ft) baltic birch.
I think I need to practice on cheap(er) materials for a while. And perfect a whole bunch of isolated router operations like slot cutting, rabbeting, dadoing, etc. Had hoped to jump right in and do something modestly productive . . . and it's looking now like, what with tax prep, mother visiting, trip to LA for a cousin's wedding, and other things, I'll be lucky to get some basic skills down before April! Color me frustrated...
