Another New Member
  • WoodPirate
    • Jan 2005
    • 312
    • Jacksonville, FL, USA.
    Another New Member
    Hi everybody!
    Yep, another newbie. I've been checking out the site for some time, but just recently got around to joining. Things are slow in the shop right now because of the Super Bowl crowds here in Jacksonville. Maybe after this weekend I'll be able to finish those new pantry shelves. I'll post pics after I'm done. The builder of this home could definitely add "square", "plumb", and "straight" to their vocabulary.
    I definitely like the Ryobi saws. I have the BT3100 + acc kit and the 12" comp miter. Both are great. I also have the Ryobi 3-base router kit. I agree with some of your comments about this one. It's nice, but I'll probably go the Porter Cable route in the future. The Ryobi 12" drill press is really nice to have, too, but I think I need to tighten the spindle. It's a bit wobbly. The Ryobi 6" thin line grinder keeps stuff sharp and polished, too. Other things that found their way to my shop are:
    Makita ROS, Dewalt drill, Dewalt Sawzall, cheap junky B&D jigsaw, Dremel scroll saw, VS Dremel tool, Ridgid 14" band saw (really proud of that one - Christmas gift from the LOML), and a myriad of hand tools, jigs and hardware. I still need to get a planer. Been looking at the smaller portable jobs: something between the Ryobi and the $500 13" Dewalt. Can I beg for some insight on this one?
    Most of my projects have been small items. I make Christmas ornaments, picture frames, and small boxes from exotic hardwoods. Anybody got any suggestion where to buy the exotics that doesn't include Woodcraft? That's a great toy store to visit, but buying stuff there is only for lottery winners.
    Lately, I've been working on a set of 5 14" deep shelves that mount in a kitchen pantry. 4 edges touch the walls in an L shape (the back wall is a 45 (yeah, right), and the front edge is an arc. Getting the template right was about as hard as chinese arithmetic. I'll just say that I'll be VERY happy when this one is finished.
    This is a great site with lots of info put out by a bunch of very helpful and apparently nice folks. I may just have to stay around a while!
    --==<< Steve >>==--
    Praise the Lord and pass the ammunition.
  • BobSch
    • 4385
    Hi, Steve. Welcome to the asylum I've been a member of this site for a while now and you won't find a better place to get answers. The gang here knows what they're talking about and are great about sharing their knowlege.
    Paint the red line, make some sawdust and have fun!
    Bob
      That's my line, Bob.[B)]
      Welcome to the Asylum, Steve!
        Welcome, Steve. I've noticed your handle on a few posts but it's nice to be formally introduced, so to speak.
        This thread in Tool Talk contains some current chatter on thickness planers, and a forum search will turn up plenty more.
        Good to have you aboard!
        • RickLab
          • 318
          • Plano, TX, USA.
          Welcome Steve!
          As for your question about insight on a planer purchase - you may want to stay tuned to this thread:
          http://bt3central.com/forum/topic.asp?TOPIC_ID=17129
          Edit : too slow as usual [:I]
            Welcome Steve. Glad you decided to become part of the group.
            • gmack5
              • 1972
              • Quapaw, Oklahoma, USA.
              • Ryobi BT3000SX & BT3100
              Welcome Steve,
              Congratulations on the acquisition of your BT3100 and welcome to the "family".
              One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the preceeding proceedure, so you MUST keep them in sequence.
              Here's some free plans that'll take keep you busy for a while. http://www.woodworkersworkshop.com/r...ex.php?cat=102
              Regardless of what you've read or others have told you, NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes. The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
              entire saw. Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
              You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/ The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site). One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
              This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea. One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
              A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
              George
                Hi WoodPirate, welcome to the board.
                • JeffW
                  • 1594
                  • San Antonio, Texas, USA.
                  Welcome to the madness. Great group here.
                  Measure twice, cut once, screw it up, start over
                  • monte
                    ***** Windbag
                    • 5242
                    • Paw Paw, MI, USA.
                    • GI 50-185M
                    Welcome to the group Steve! Enjoy the site!
                    Monte (another darksider)
                    • Popeye
                      • 1848
                      • Woodbine, Ga
                      • Grizzly 1023SL
                      Welcome aboard. Good to see someone else from my neck of the woods. That may be streaching alittle but....I'm up in "Metro Woodbine" 45 miles north of Jacksonville. Pat
                        And another Welcome! Post some picts of the shelves when you complete them; and also some of your other work. We would love to see it.
                        • Woodnut
                          • 605
                          • Modesto, CA, USA.
                          In the Sarasota area is Angelo Tumminaro Cabinet & Millwork, Inc.
                          They may be able to get you exotic woods at a better discount than Woodcraft.
                          It's not their primary business, but who couldn't use another revenue stream these days...
                          2211 Industrial Blvd, Sarasota, FL, 34234
                          (941) 351-7080
                          angelo@millworkmania.com
                          Woodnut
                          "I should know better, but where's the fun in that?!"
                          • Ken Weaver
                            • 2417
                            • Clemson, SC, USA
                            • Rigid TS3650
                            Welcome aboard Steve. My Mom lives in Jax, maybe we can hook up sometime.
                            Ken Weaver
                            Clemson, SC
                            • Slowpoke
                              • 244
                              • WNY, USA.
                              Welcome to the mix Steve ... Sounds like you have a great start on a nice shop setup.
                              [8D]
                              "if partners always agreed, one of 'em wouldn't be needed"
