Guys - is there a favorite plan for a cross cut sled for the BT3 - I do have the extension (left) with the miter slots. Do I need to add the Right extensions as well - My saw does not have the holes to add it will have to modify. Or is the left enough to be effective? I have seen a lot of plans on the web some seem better than others - hard to tell if they are usable on the BT3. Thanks in advance for the help!
Cross cut sled
I've had pretty good luck with using just the one miter slot on the left. I tried a sled that used my right slot too, but I had problems with it binding and not sliding smoothly. It's not easy to have tight fitting sliders and have both slots lined up exactly parallel.
Big deep sleds aren't easy to handle on a BT since the table isn't all that deep, unless you have some infeed and outfeed support.
I don't have a mitersaw much less the room for one. The sled I use the most is this dual function crosscut sled. http://www.bt3central.com/showthread.php?t=51932 I do wish I made it with replaceable zero clearance inserts.Erik -
I made this one from Shopnotes and really like it:
http://www.shopnotes.com/plans/crosscut-sled/exploded/
Try to plan zero clearance plates into the front and rear fences; dados make permanent changes to the fences.Bill in Buena ParkComment
this was developed for a more traditional TS,but some of it may be useful:
https://www.ridgidforum.com/forum/t13945/
i built a 26" deep by 42" wide sled that is dead on accurate using niki's methods. allows for CCing panels for cabinets.there's a solution to every problem.......you just have to be willing to find it.Comment
Niki's links
Guys for some reason the pictures do not show on Niki's link for me. Anyone have that problem. I have been refered there several times but to no avail.Beaux Ti -
If you see a Bomb Tech running, follow him....Comment
try here:
http://www.bt3central.com/showthread.php?t=49793
scroll down to "crosscut sled, a different way".there's a solution to every problem.......you just have to be willing to find it.Comment
Toolguy1000, it ends up at the same thread you linked to earlier.
BeauxTi, It may be some security settings in your browser. I initially couldn't see them, but if I allowed my browser to view the unsecured content (by clicking No in the popup) they came through.ErikComment
Pelligrini's on it--allow non-secure content and the photos show. WOW!! The knobs alone are worth the time to look. The few i browsed through were simple stuff--but so clever. No TV for me tonight!!
earlComment
funny, when i click on the first link, it brings me to the ridgid.com forum (and the niki thread recap there). the second link may be the same information, but it brings me to the niki thread recap on this forum. is that not what happens when you click on those links?there's a solution to every problem.......you just have to be willing to find it.Comment
If I follow your direction of "scroll down to "crosscut sled, a different way". " and take that link off of the recap BT3central thread list it resolves to the same ridgid.com link you made in post 4 of this thread. They both end up at Niki's great crosscut sled thread.funny, when i click on the first link, it brings me to the ridgid.com forum (and the niki thread recap there). the second link may be the same information, but it brings me to the niki thread recap on this forum. is that not what happens when you click on those links?
There's this one too: http://www.bt3central.com/showthread.php?t=32511ErikComment
i didn't realize the bt3 link reverted back to the ridgid forum posts. the important thing is the last link you provided. it will hopefully be helpful to the OP.If I follow your direction of "scroll down to "crosscut sled, a different way". " and take that link off of the recap BT3central thread list it resolves to the same ridgid.com link you made in post 4 of this thread. They both end up at Niki's great crosscut sled thread.
There's this one too: http://www.bt3central.com/showthread.php?t=32511there's a solution to every problem.......you just have to be willing to find it.Comment
Hopefully it will help. The images in the BT3Central thread are the same ones contained in on the ridgid forum thread, but the BT thread isn't HTTPS like the ridgid one.ErikComment
Beaux,
I have been happy with my sled for several years. I don't remember who I borrowed from.
I just use both of the left miter slots. One with the blade at 90 degrees and one at 45.
I also made a simple stop, to avoid cutting through the blade guard.
Over the years, I have made modifications. There are "T" nuts a several locations to add hold-downs, for repeat or risky cuts.
I use the sled often as it feels the safest to me.
I would never die for my beliefs because I might be wrong. Bertrand RussellComment
Niki WOW
I allowed unsecured view - got the pictures- that Niki is amazing - that sled has got to be perfect. Simple but inventive - I looked at some of his other works - very cool. I think I need to pick up a couple of the plastic triangles - guessing a drafting supply or maybe office Depot. I am going to spend some time going over his posts - although the the idea of an adjustable Kerf slot would allow for the Dado. Start simple right ;-)Beaux Ti -
Bill in Buena Park -
how did it come out - like the idea of the adjustable Kerf. I am still new to this but willing to mess up some wood getting there.Beaux Ti -
