I found a 4" drainage line at HD. The outside is white PVC and the inside is black HDPE. The dust collector fittings are a tight press fit. I used it to connect the blast gates directly to the 4" to 2 1/4" reducer adapters. Go glue required. HD has PVC fittings for this pipe in the $2 to $4 dollar range. A 10" x 4" pipe is $4.99.
The pipe is staticy but a ground wire should fix that. Its cheaper and lighter than standard 4" PVC and you dont have to customize the 4" adapter.
To adapt your dust collecter fittings to the drainage fittings just cut a couple of inches off the tube and press fit to the DC fitting. Then glue the cut sleeve to the drainage fitting.
Has anyone used this to outfit a shop for dust collection?
