I need to repair some outdoor furniture - chairs and a bench. They are made from nyotah, which is supposed to be similar to teak. I've never worked with either, but I'm sure a few of you guys have.
The joints are all pinned mortise and tenon corners and most are loose while some tenons have pulled right through the pin and the joint has fully separated. What's left on these pieces is a tenon with a section torn out of the middle.
The fit is loose enough that I don't trust just glue to hold these together and I don't think I can secure them across like the pins did because of the damage. My thinking right now is to take the joints apart, clean them up, glue them and then use a deck screw (or two on the bigger ones) through the back of the mortise and into the tenon.
Is this the best way to repair the joints, or is there a better way? And what glue would work best here? I have Titebond II, but am I better off with Titebond III, Gorilla or something else?
Thanks for any advice.
