Hi all,
I have a 1 HP Crafstman DC (13 or 14 years old). I think it is about 600 CFM. It has worked well, but I am now getting ready to build a real workshop in my basement room (approx. 14' x 34'). I was wanting to run a 4" pipe with several blast gates for the various equipment I own (BT3000, Delta portable 12" planer, miter saw, very old Crafstman bench to 4" jointer/planer). I am planning to replace my jointer/planer with something a little more usefull & will be getting a drill press. I may eventually get a band saw & have even thought about playing with a lathe some day.
All that gets me to my question. Should I replace my old dust collector with something like the HF? I do not believe Wynn makes a filter that will easily fit on my dust collector, & frankly, it throws out a fair amount of fine dust when running. Can I get another and run both in parallel? Should I try to adapt a Wynn filter & bag to mine & see if that helps?
I know I am rambling here, but I value your input as I will need to keep dust down to a minimum in this shop (near furnace and next to a finnished room).
Thanks in advance for your input!
