Thanks BT3 Central!
  • Chinook119
    • 8
    • Chambersburg, PA
    • Ryobi BT3100-1
    Thanks BT3 Central!
    Hello everyone. I'm new to the hobby and joined the forum only a few weeks ago. I just wanted to say thanks to everyone for helping me without realizing it. My dad is a member and recommended I joined the forum and between his help and everything I've learned here, I haven't had to post a single question yet. Although I'm sure I'll think of plenty more. This is a great place and thanks again!
    Welcome to the site. Since I have no idea what I'm doing, I'll say "Thanks" too.
      Howdy Chinook, I used to "ride ya" in Viet Nam. Never wanted to get out, but they insisted. ha.. ha...
      Welcome from another new to the forum, clueless one. But.. we'll figure it out eventually with a bit of persistence.
      Gotto go to the shop now to cut some tenons in stretchers to mate to alaready cut mortises on table legs. I figure if I cut em undersize and just wrap duct tape around them, they'll eventually fit. Just kiddin' bout that part.. :>)
      Who's your dad?
      Regards...
      • gmack5
        • 1972
        • Quapaw, Oklahoma, USA.
        • Ryobi BT3000SX & BT3100
        Welcome to the Family
        Welcome Chinook119,
        Congratulations on the acquisition of your BT3100 Table Saw and welcome to the "family".
        One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the one before it, so you MUST keep them in sequence.
        A good one will cost you quite a bit of money, $40 - $75, or more.
        I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
        When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
        Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate.
        Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes.
        The reason is simple, most of them contain Silicones and they will make your projects difficult, if not impossible, to finish.
        entire saw.
        Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
        You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: https://www.sawdustzone.org/articles...nce-check-list
        The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site).
        One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
        This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea.
        One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
        George
          WELCOME TO THE FORUM CHINOOK
          Glad to have you here. Now no one will wonder where you are late at night. Some great info here, and don't be afraid to ask questions.
          • Chinook119
            • 8
            • Chambersburg, PA
            • Ryobi BT3100-1
            Thanks for the warm welcom everyone. Sarge...thank you for your service to our country. I did some time in the service but I didn't see any action. Oh, my dad is BillB in Pa.
            Gmack5...wow thanks for all the info and links...after the little one goes to bed, I'll be back here checking them out.
            • lcm1947
              • 1490
              • Austin, Texas
              • BT 3100-1
              Yes indeed welcome to the forum and now that you got the standard welcome from gmack5 you should be set for awhile. Look forward to seeing you around. It's always nice to get a new member to the forum.
                Welcome aboard Bill.
                  Welcome. Gladd to have you aboard. There are at least a couple members up in PA.
                  • bigstick509
                    • 1227
                    • Macomb, MI, USA.
                    Welcome
                    • Wood_workur
                      • 1914
                      • Ohio
                      • Ryobi bt3100-1
                      welcome aboard buddy.
                      Alex
                      • GeekMom
                        • 752
                        • Bonney Lake, WA.
                        • Shopsmith Mark V
                        Welcome to the most helpful and friendly forum around!
                        Karen
                        • softop41
                          • 470
                          • Plainfield, IL, USA.
                          Chinook,
                          Welcome to the best Woodworking forumon the 'Net, period!
                          Jerry
                          Jerry
                            • 8795
                            Welcome Bill! Join in the fun here and let us get to know you! Glad you signed up.
                              Welcome to the forum Bill. Enjoy yourself.
