stile & rail router bit
  • onedash
    • Mar 2005
    • 1013
    • Craftsman 22124
    The raised panel bit in that set seems like there isn't much to it.
    Are these more likely to kick back???
    • fiasco
      • 144
      Is a planer or jointer required to build raised panels (since I assume that I have to join some narrower stock to get a wide enough board for the panel insert)?
      Is a Hitachi p13F 13" planer decent? I know where one is for $200 new in box.
        Fiasco,
        There are two bits in the set you mention which I do not have and have not needed - the glue joint bit and the door lip bit. If you can get the panel raiser and cope/stick bit for less, you might want to go that way.
        Normally you will have to glue up stock and make it flat if you want to make raised panel doors. I say normally because I have made painted doors with MDF panels. You do not need a planer, however, to glue up the blanks of solid wood. I typically use a belt sander to to flatten the panel before raising the panel. I then finish sand the panel and put finish on it before glue-up. That eliminates an unfinished edge if the panel shrinks (from reduced humidity/moisture content).
        • fiasco
          • 144
          I already ordered the set.
          I'm getting my wood shop together. I have many projects in mind but I'm starting out with two 27w x 30h x 12d double door wall cabinets followed by a 36" bathroom vanity.
          I got a planer and I'm looking for a jointer. I plan on using rough cut wood instead of the pre-milled HD/Lowes propellors.
