which router bit set for a weekend warrior?
  • vaking
    • 1428
    • Montclair, NJ, USA.
    • Ryobi BT3100-1
    Originally posted by gychang
    any particular set, ?web page?
    thanks,
    gychang
    This will get you going: http://www.mlcswoodworking.com/shops...et15piece.html
    It does seem that most manufacturers are now trying to sell you a 30-bit set. One more thing - if your router supports 1/2" collet - get a set with 1/2" shank and avoid 1/4" shank sets. Bigger bits are sturdier, have more carbide and dissipate heat better. 1/2" shank is preferred for all but very small bits.
    Alex V
    • raney
      • 9
      Just to chime in a little:
      I bought this from holbren for a 'starter set':
      http://www.holbren.com/product.php?p...6&cat=0&page=2
      36 bits for $60 is pretty hard to beat for decent carbide bits. Plus, I really like dealing with Brian at Holbren - excellent CS.
      They also have a 35-bit set with 1/2" shanks for $100 that's a great deal, but I went with the 1/4" because they fit my 'palm router' as well as table and plunge models
      Why I would do the same thing again:
      Other than some specific stuff like raised panels, and lock-miters, etc, whenever I started a new project and wanted a certain bit (rabbeting, straight, coves, roundovers, flush-trim) I already had it.
      As others have said, the ones that I use the most have gradually been replaced by higher quality stuff from CMT, whiteside, and Freud - though I have to say that the holbren bits have been of really surprsing quality considering their price.
      You probably can't go wrong with the whiteside set at holbren either - you'll use all of those bits a LOT, and that's a great price.
      Have fun.
      • Doug Jones
        • Oct 2004
        • 332
        • Indiana
        • Delta 36-444
        I got to go with the 35 piece 1/2" shank Holbren set that was mentioned earlier. More than likely it has bits you'll never use but even so they are a great bit at a great price.
        • jarhead
          • 695
          • Boynton Beach, FL.
          There was a magazine article recently (check your local library, don't remember the name), that had the 10 most needed bits.
          You're most likely refering to FWW magazine issue 186
          • Larry David
            • 82
            • Maryland.
            Holbren bits
            A great set from Holbren. It was my first set. Good price too.
            http://www.holbren.com/product.php?p...=24&bestseller
            • onedash
              • Mar 2005
              • 1013
              • Craftsman 22124
              Can't beat the $5 bits at Woodcraft. They are pretty good bits. Besides my Raised panel set I think my tiny little Keyhole bit was the most expensive bit I bought. Some are normally more but I got em on sale.
              As a rule though I try to buy the better quality blades and bits now. Even sand paper. They might cost a little more but if they outlast the cheaper ones its gonna save $$$. And if you buy more the price goes down. Box of Sandpaper and multipacks of recipricating and sabre saw blades....
