New Table Saw Report
  • mmeyerkopf
    • Sep 2006
    • 21
    I just wanted to let everyone here know that I am delighted with my new Craftsman 21829 (Ryobi BT 3100 +).
    It is incredible. I have been using a small benchtop Craftsman that my father bought in 1939 with no Rip fence and questionable motor. Wow - what a difference.
    Smooth, perfect cuts (completely square) - outstanding rip fence that cuts exactly the length you have selected.
    I also have bought a Ryobi 10" Drill Press and 9" Bandsaw (that is all my workshop and wallet could manage.) I am very impressed with the heft of the Drill Press. Heavy gauged steel and beefy components. I grew up working with my Dad, he was Tool and Die Maker, and these tools bring back memories (now if I could only afford a Bridgeport milling machine.)
    Anyway thanks for all the advice and quick responses to all me questions. I feel as if I will continue to need help as my tools bring me new confidence.
  • nadz
    • 82
    • Rocket City, AL, USA.
    a table saw from 1939?
    can i see some pics please?
    wow...
    Proudly piddling in my garage shop | BT3K, Rigid 10" CMS, Rigid 12" Planer, HF Jointer
    • nadz
      • 82
      oops
      hey, congrats on the new saw btw...
      -nadz
      • gmack5
        • 1972
        • Quapaw, Oklahoma, USA.
        • Ryobi BT3000SX & BT3100
        Welcome to the Family!
        Welcome sackeri,
        Congratulations on the acquisition of your 21829 Table Saw and welcome to the "family".
        One of the first things you need to do, after you get your 21829 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the one before it, so you MUST keep them in sequence.
        A good one will cost you quite a bit of money, $40 - $75, or more.
        I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
        When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
        Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate.
        Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes.
        The reason is simple, most of them contain Silicones and they will make your projects difficult, if not impossible, to finish.
        entire saw.
        Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
        You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/
        The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site).
        One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
        This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea.
        One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
        George
          George
          That was an extremely complete guide. Should be a sticky. If you have kids, I'd like to hear your discussion with them on the birds and bees.
          • Knottscott
            • 3815
            • Rochester, NY.
            • 2008 Shop Fox W1677
            Congrats on the new goodies....have fun!
