Just thought I'd post some Newbie safety observations I had last night while ripping some pine boards (1 x 10's and 1 x 12's) down to size.
1) Had a knot jump out of one board and get caught within my Shark Guard. Would have been a pretty good projectile if the guard wasn't there! Original BT3 guard probably would have worked also? Gotta respect those knots!
2) Had one board "develop" a bad warp as I cut it. Cutting released the "tension" or whatever within the board. I stopped cutting and pulled the board back. Looking back at where the cut started, one side of the cut was now warped up about 1/4 inch higher than the other side. Never saw that before but had heard about it.
What with loose knots and movement during and after cutting, you just never know what exciting things are going to happen. Not to mention the fun you can have trying to get an even finish
I use a lot of un-kiln dried pine (band sawed from my logs) and can attest to "ripping" problems. I've had short pieces (20-25") actually stop the saw even though they were air dried for months. Even the shark splitter won't let it through. Local joke is that they were grown too close to the creek! Actually a lot of the problem is trees that were grown on steep slopes develop a lot of stress on the uphill side in trying to grow straight up. The internal stress/tension can be fierce. Some times I "shim" the cut after it is past the saw blade (have to take out the shark first), usually this works. Wood caan be a real "head scratcher" sometimes.
