What to buy----What to buy
  • rcp612
    • 358
    • Mount Vernon, OH, USA.
    • Bosch 4100-09
    I've come into possesion of $260.00 of Lowes gift cards.
    What should I buy next? Drum sander?,,jointer?,,planer?,,drill press??
    Or should I just give it up and buy what's needed for a project?
    I have a BT3100, belt sander, bench grinder, circular saw, electric drill, cordless drill, cordless circular saw, compressor, brad nailer, and finish nailer. What would be the logical thing to buy next in your opinion?
    Router. Without question. Given what tools you already have, and the amount of money at your disposal, a router is a perfect fit and will expand your capabilities more than you can possibly imagine.
    This, however, is the general, not-project-specific answer. If you have some project upcoming for which you must have a [insert name of tool here] in order to build the project, then that's what you should buy.
    One other possibility, although not exactly a "tool," would be a dust collector.
    • rcp612
      • 358
      • Bosch 4100-09
      Sorry!!
      I forgot to mention I have a router too. Forgot about it now that it's table mounted.
      • Knottscott
        • 3815
        • Rochester, NY.
        • 2008 Shop Fox W1677
        Planer.......
          Put a DC on the list and a ROS, some glue, chisels, block plane, and a tape measure should eat up the gift card.
          • RodKirby
            • 3136
            • Mao Shan TSC-10RAS
            Drill press
            Downunder ... 1" = 25.4mm
              You say you already got a router? What's your point? Buy another one.
              I think I'd go along with "planer", myself. Or maybe a compound miter saw, if you do a lot of cutoff work. Given that you have to shop at Lowe's, those are the best choices that come to mind.
              • mschrank
                • Oct 2004
                • 1130
                • Hood River, OR, USA.
                You are obviously too indecisive to be trusted with that gift card. Save yourself some trouble and just sent it to me.
                Of the items on your list, I would have to agree with Rod and say drill press. I use mine way more than I ever thought I would, and don't know what I'd do without it.
                • SHADOWFOX
                  • 1232
                  • IL, USA.
                  • DELTA 36-675
                  With the gift card amount that you have I would go with the DC or Drill Press. You could send it to me and I'll buy a drill press with it.
                  Chris
                  • Russianwolf
                    • 3152
                    • Martinsburg, WV, USA.
                    • One of them there Toy saws
                    Don't use your card to buy a Radial Arm Saw.
                    that's what CraigsList is for. They always show up for under $300 on there, much cheaper than store bought.
                    You're not getting a drum sander from lowes for $300. I would look at a spindle sander or a planer as was mentioned earlier.
                    Lakota's Dad
                    • BrazosJake
                      • 1148
                      • Benbrook, TX.
                      • Emerson-built Craftsman
                      I can see this is a real problem, so just send those gift cards to me and I'll dispose of them properly:-)
                        Or from anywhere, for that little money, to my knowledge. IIRC even that new closed-end Grizzly model is more than that.
                        OOC, is it possible to get a decent drill press, at Lowe's, for $260? Aside, that is, from the infamous $120 Hitachi, or whatever it was? I was under the impression a DP from one of the big box stores would be ~$100 more, i.e. up around $350.
                        • Turaj
                          • 1019
                          • Toronto, Ontario, Canada.
                          • BT3000 (1998)
                          Originally posted by RodKirby
                          Drill press
                          Another vote for Drill Press!
                          Turaj (in Toronto)
                          • vaking
                            • 1428
                            • Montclair, NJ, USA.
                            • Ryobi BT3100-1
                            I agree with Drill Press based on frequency of my use but why don't you ask yourself what kind of projects you plan to work on. If you are thinking pens - get a lathe.
                            Larry,
                            About drill press and big box stores - My DP is 14" floorstanding Jet from Costco for $170. Does it qualify?
                            Alex V
                              • 10481
                              Given what you already have, go with a drill press.
