Well, after cooling off for a little bit (literally and figuratively), I went back in the shed, removed the riving knife AGAIN, and used everything I had available (pipe wrench, 4x4, my knee, my foot...) and tried to really straighten it out this time. Adjusted the shims (again), and it actually looked good. I finished ripping the remaining pieces of plywood for the table saw mobile base I'm building. It went without a hitch, except for the *#$&^ pawls.
I put some electrical tape on each tooth on the pawl on the left side, just to see how that works. I think it works better. I was only getting resistance and binding on the right pawl now. So I'll probably tape that up, too.
The plywood that binded (bound?) in my previous post is oak veneer. After I "fixed" the riving knife, it went through just fine. Good thing, too, because I'm no longer allowed to buy any more new tools (e.g. Shark Guard) until I get all the ones I already own properly assembled and installed in my shed (and hence the rush to finish up on the mobile bases and bench). Do you guys also end up hiding illicit tool purchases in the unlikeliest places (like the laundry room or under the bed)?
Anyway, thanks so much for all the help and encouragement.
I don't think I would have made through this day without this forum. I know it's a little problem in the grand scheme of things, but it was really frustrating nonetheless.
Thanks again,
Anna
I don't think I would have made through this day without this forum. I know it's a little problem in the grand scheme of things, but it was really frustrating nonetheless.Thanks again,
Anna
The solution was putting shims on the arbor to move the blade just slightly left. Lee sells (clearly marked!) brass shims that can be ordered along with the SG. These fixed the alignment problem and things have been working fine since.
