Ever hear of 1/4" MDF?
  • lcm1947
    • 1490
    • Austin, Texas
    • BT 3100-1
    Well, I hadn't, until today at HD that is. I was very pleased as I have a couple of ideas for this stuff. Neat! especially since I can't seem to find 1/4" pressed board around my house.
  • Ken Weaver
    • 2417
    • Clemson, SC, USA
    • Rigid TS3650
    Have seen the hardboard and pressed board but never MDF below 1/2" Good pattern stuff I bet.
    Ken Weaver
    Clemson, SC
    • JoeyGee
      • 1509
      • Sylvania, OH, USA.
      HD has had it around here
      HD has had it around here as long as I can remember. I don't recall if it comes in 4x8, but I buy the 2x4. Ken is right, it is perfect for making patterns.
      • MilDoc
        Works great for templates! just hate the dust!
        • lcm1947
          • 1490
          • Austin, Texas
          • BT 3100-1
          Yes it's 2x4 but that's fine with me. I can tote it in my sedan.
          • RodKirby
            • 3136
            • Mao Shan TSC-10RAS
            Been using 1/4"/6mm MDF for YEARS! (Yes, Loring; I know 1/4"=6.35mm)
            In fact, in Oz, the 6mm MDF is a poofteenth larger - maybe moisture?
            I use a 1/4" spiral bit to rout dados for it and the fit (with glue) is perfect.
            Downunder ... 1" = 25.4mm
              • 8799
              We have 6mm in Japan too. Nice stuff and great for special projects. Mac, it works great with an Impact Driver too.
              • RayintheUK
                • 1792
                In the UK, MDF is available in
                4mm
                6mm
                9mm
                12mm
                15mm
                18mm
                25mm.
                All come in 1220mm x 2440mm (4' x 8') sheets.
                Additionally, you can get 18mm (3/4") in
                1220mm x 3050mm (4' x 10')
                1525mm x 3050mm (5' x 10').
                Spoilt for choice, really!
                Ray.
                Did I offend you? Click here.
                • BobSch
                  • 4385
                  That's a lot of choices you've got Ray, but 5'x10' sheets of ¾" MDF? Do they supply a forklift to move it around?
                  Bob
                  • lcm1947
                    • 1490
                    • Austin, Texas
                    • BT 3100-1
                    Leehljp what impact driver? See I'm already over it. And Rod can I ask you why a spiral bit and not just a regular say 1/4" straight bit?
                    • RodKirby
                      • 3136
                      The spiral "slices" the fibres more cleanly than the "scrape" from a straight bit.
                      And I meant to say before - in Oz a lot of use is made of 3mm (1/8") MDF - eg melamine one side for drawer bottoms. I use it often for full size layout plans.
                      • RayintheUK
                        • 1792
                        Yes, Bob, a 5' x 10' board of 3/4" MDF weighs almost 140 lbs. so they are a bit of a swine to handle. On the few occasions I've had to use such a sheet, because of the length required, I got my supplier to cut it roughly to width for me first, but there's no way I'd want to try and handle a full sheet on the BT3!
                        Ray.
                        • lcm1947
                          • 1490
                          • Austin, Texas
                          • BT 3100-1
                          Thanks for the reply Rod. I see. Boy there is just a lot to learn about bits but I learning. Thanks again.
                          • bigsteel15
                            • 1079
                            • Edmonton, AB
                            Might be a silly question, but isn't hardboard basically the same as MDF.
                            The amount of dust is sure similar.
                            Brian
                            Welcome to the school of life
                            • RodKirby
                              • 3136
                              Very different stuff, Brian.
                              In Oz: hardboard = masonite = nearly black in color. Dimpled on one side, flat on the other. Filthy stuff to work with. Also sold here as pegboard sheets. 6mm thick only
                              MDF = Medium Density Fiberboard = differing "pale" shades of beige.
                              Multiple thicknesses available. OK to work with "sensible" DC - I love it!
