Brass Router Bushings - Woodcraft vs. Rockler
  • captbooshz
    • 13
    • West Monroe, LA, USA
    Can anyone give me an experienced comparision between the brass router bushing sets that Woodcraft and Rockler offer?
    Just from what I've read, I had decided that I would go with the Woodcraft set. The .240 depth on all the guides seems intelligent, allowing 1/4" templates, vs. most of the other sets I've seen that have much deeper depths on the larger diameter guides. Would you agree or disagree?
    Rockler has their set on sale now for $19.99. A month or so ago, Woodcraft had theirs on sale and I missed it. I don't need them immediately, so I had decided to wait and see if Woodcraft would have them on sale again sometime in the next few months. Besides the shorter depth, they seem about the same.
    Thanks for your input.
    Brian.
  • Thom2
    • 1786
    • Stevens, PA, USA.
    • Craftsman 22124
    I have both styles .... definately buy the woodcraft set and don't look back. The other style is pretty much useless IMO. I wish I knew then what I know now
    • bigsteel15
      • 1079
      • Edmonton, AB
      I'll second that.
      I've been wondering recently why the Bosch set has all these long bushings.
      Even the ShopFox set I have is a little too long (1/4") for the General DT jig I have.
      Keeping my eyes open for a shorter set.
      Brian
      Welcome to the school of life
      • gmack5
        • 1972
        • Quapaw, Oklahoma, USA.
        • Ryobi BT3000SX & BT3100
        I also have both the Rockler and the Woodcraft sets and like Thom2, had I gotten the Woodcraft (.240") set first, I would never have looked back.
        George
        • Bollox
          • 113
          • Indianapolis, IN, USA.
          I bought the Rockler set, and fairly soon ended up shortening them all to a bit less than 1/4 inch. I did it in a lathe, but you could do it with a hacksaw and file. Thats probably how I'll do my Bosch bushings rather than trying to chuck them up in the lathe.
          Eagle America has a short PC style set which is often on sale.
          • os1kne
            • 901
            • Atlanta, GA
            I discovered the same problem yesterday - I went to use my Rockler bushings and found that they were too long to use with several of my router bits. Not good. I'm not sure what the designers were thinking - they could have saved a lot of material AND made a better product in the process (most problems seem to be the other way, where if the manufacturer spent a few more pennies, the product would be much nicer.)
            • L. D. Jeffries
              • 747
              • Russell, NY, USA.
              Router Bushings
              Definately go with the Woodcraft set. I've had a set for years; the biggest selling point was the standard height of the bushings! No fiddling around building up a template or anything else. Easiest template material is tempered masonitte which is 1/4 inch thick, not too expensive and easy to use; I've also used 1/4 inch MDF for templates. That works great too!
              RuffSawn
              • captbooshz
                • 13
                Thanks to all for your input. Mike, thanks for pointing me to Eagle America; I hadn't checked there. Looks like their set is virtually identical to the Woodcraft set, only theirs are a tad shorter. They have them on sale now for $20, $26 shipped. I'm thinking I may just go ahead with those.
                Thanks again.
                Brian.
                • djmst38
                  • 17
                  I have also been looking at these but am wondering if they will fit any router? I have a Dewalt router I use for hand routing.
                  • bigsteel15
                    • 1079
                    • Edmonton, AB
                    They will fit any router that has a 1-3/16" (I think that's right) hole designed for "PC" bushings.
                    Some routers have an adapter you need to affix first.
                    Brian
                    • RickT
                      • Jun 2003
                      • 175
                      I picked up the Woodcraft set a few sales ago. They're on sale quite often. I looked at the Rocker and Woodcraft. I decided on the Woodcraft because of the shorter length and sizes in the kit. The Woodcraft set includes a guide bushing with a 1" OD, which I needed. The Rockler set goes only to 51/64".
                      Rick
