Hi everyone. I'm sure this has come up before...
I tried aligning my SMT fence last night with no luck. I did do the table alignment first as documented in the manual. I had good luck with that. When I got to the SMT fence things didn't go so good. I followed the steps in the manual but when it says to start turning the left rear eccentric screw until the fence is parallel to the blade I was never able to get it aligned. It seemed like the eccentric screw didn't give me enough travel to move the top out far enough to get my 90deg square flush at the fence and blade. I'm going to try the entire procedure again over the weekend but any advice would be helpful.
Thanks Chadi
Thanks Chadi
