I have already asked several questions before. Thanks all for the useful information. Here are some more:
1. I have PC690LRVS router mounted on a router table. I have tried to use this for raised panel (cove profile). It worked but you have to pass 8 to 10 times in order to cut the profile. This is kind of time consuming. I come up an idea that I can use Table Saw to remove most of the material before I can use router. The problem is that I have to use high vertical fence. I have measured the bevel angle to be about 18 degree, just need to raise up the featherboard to hold the board against the fence. I have not tried this yet, I don't know if anybody in this forum have ever tried this before, or any advice on this.
2. What is the best way of join face frame to the carcass. I am thinking of cutting groove on face frame, then use glue. But I am not sure about how strong this will be, do I need to use biscuits to enhance it or like some people just staple, which I don't preferred.
3. Since I am using Cherry to make the raised panel door and face frame, I would like to know what kind of finish is the best. I am currently prefer the dark stain like most of the cherry cabinet displayed in the homedepot, but not decided. I was also thinking of keeping its natural color and only apply polyurethane, but seems like a little bit wired (just my 2 cents). I would like some advice on this and also what brand and kind of stain to use for the best results.
4. As to the plywood used to make carcass, I noticed that most of the cabinets in homedepot use 3/8" thick plywood, this is not carried in either Homedepot or Lowes store. I think I will have to use 1/2" plywood. The price for cabinet grade plywood in both homedepot and lowes is kind of high, anybody know alternative source that has decent price? BTW, I am living in big Boston area.
Thanks in advance for any suggestions and advice!
