2 Finishing Tricks I Just Learned
  • Jeffrey Schronce
    • 3822
    • York, PA, USA.
    • 22124
    1) You know how you get putty or filler into the grain of the surrounding wood when you try to fill a nail hole? Just place a piece of quick release masking tape where you will be shooting the nail. You can fill the hole through the hole created in the tape by the nail. When you are done just zip the tape right off.
    2) You know how you can get finish in the rim of a metal can and then the lid will not fit properly? Take a awl and punch a few drainage holes in the lowest part of the rim. These holes will allow the product to go back into the can and will not cause evaporation because the lid will seal above them.
  • DaveW
    • 415
    • So Cal.
    On a related note, has anyone tried using those plastic paint can "lip"s with wood finishes? I've used them with paints, and they've worked great for me - and they keep the paint out of the rim altogether.
    • Tom Miller
      • 2507
      • Twin Cities, MN
      Geez, I always thought that finish around the rim was giving me a better seal. Maybe just the first time, though.
      I like idea #1. I'm sure I'll forget it by the time I need it, though.
      Regards,
      • Jeffrey Schronce
        • 3822
        • York, PA, USA.
        • 22124
        Dave, I think they would work perfectly well with thicker items like straight poly. I think you would still get some in the lid of the can with Shellac Mixes, etc where there is lots of solvent. Of course lids don't get as stuck with high solvent finishes.
        Tom, unless you were joking, my mileage varied greatly on that one! Ya, its not a big problem the first time, but after you mess up the lid getting it off because it is stuck . . . .
          The holes in the rim I have done. I used the can spouts on the gal cans of stain when I did my porch. Worked great.
          I'll have to remember the tape idea.
          • davidtu
            • 708
            • Seattle, WA
            You know what they say, "TH... th.... th.....that's awl folks!"
            • Brian G
              • Jun 2003
              • 993
              • Bloomington, Minnesota.
              • G0899
              2(a). I use an old (small-sized) soup ladle instead of pouring finish (or paint) out of the can. Much less mess, and I can easily regulate the amount I extract.
              Brian
                I already use the nail hole in the cans but I will certainly remember to use the tape idea the next time I use a nail gun. It is a good idea and should save some sanding time. Thanks for posting it.
                  Jeff, both excellent ideas. I often don't use nails at all, but on some cabinet constructions, they make life easier. Very good tips, thanks for posting.
                  • jhart
                    • 1715
                    Been using nail holes in the cans for years. Works great!! Really like the idea #2. Sure would make clean up easier. Thanks for the tip Jeff.
                    • scoly
                      • Jun 2003
                      • 395
                      • Lubbock, Texas, USA.
                      Been using the holes in the rim for a while. The tape idea is great. Thanks for sharing.
                      Steve
                      It\'s the combined experience of the members on this board that make it such a great place.
                      • Tom Miller
                        • 2507
                        • Twin Cities, MN
                        Yeah, it was a joke -- it's how I rationalize not cleaning the rim. Gonna try the holes now, though. Thanks!
                        I've been using the same rationalization when I use those disposable tupperware containers for finish. Only the first seal is enhanced by a little finish.
                        Regards,
                        • mschrank
                          • Oct 2004
                          • 1130
                          • Hood River, OR, USA.
                          I picked up that trick re: the holes around the rim awhile back. Usually works great, but one warning...I've opened some cans of (water based) paint to find rust around the holes and in the paint. Seems some cans are coated with something to keep the inside from rusting, but that coating is compromised when the holes are punched through it.
                          • scorrpio
                            • 1566
                            • Wayne, NJ, USA.
                            Think those tips were just printed in Woodsmith last month? Or was it FWW? Anyways, good ideas. For cans whose contents is going to be used in smaller quantities, I find 'spout lids' to be the best. For larger projects, where I am likely to use the whole can, I don't bother.
                            • Jeffrey Schronce
                              • 3822
                              • York, PA, USA.
                              • 22124
                              Absolutely. You can't punch the holes in water based products or you will get resulting rust. Be careful opening the lids as well, as I have scratched to coating off allowing rust. Best bet maybe to transfer a finish or paint you don;t use frequently to a plastic container.
