Pics of my DIY shelves (or “rack”) for my stereo gear
  • JonW
    • 116
    You folks have been great in helping me out with the basics. So I want to share some photos of my first project finished with the saw and a few other tools.
    I wanted to make some shelves or a rack for all my stereo gear. I wanted it to be sturdy, but I wanted it to have a light, “airy” look, rather than be all heavy and thick looking. I drew out lots of designs, even made a template of a curved leg that I didn’t like, and then settled on this design, which I do like. Each leg has the sides rounded over, 3/4”. There is a gradual curve atop each leg, so it looks as though the curve flows from one leg top to the other. Each shelf has a camfered front edge. There is a 1.5” brace below each shelf in the rear. Overall, it’s about 4’ tall.
    I also fashioned a few hooks for the back, on shelves 2 and 5, to hold cables in place. Just a little hook type of thing to hold the cables from all the gear. To try and keep the cable spaghetti under a little control.
    It’s all Russian baltic birch. I used cheap wood because I was anticipating lots of mistakes for my first woodworking outing. The legs are made of 3/4” and the shelves are 1/2”. I already had tools, glue, polyurethane finish, etc. around from my subwoofer project. I used scrap wood and some of the birch ply here for making router jigs. The cost to me was something like $25 for a 5’x5’ sheet of 1/2” wood and then I used a quarter of a sheet of 3/4” ($38 for a 5’x5’ sheet), so something like $45 out of pocket.
    It was quite a lot of work (for me, at least) to make this thing. I worked slowly and carefully. I’m happy with the results.
    Here are the shelves all done:
    Loaded up:
    You can see the hooks in the back here:
    The long view. If you squint, you might also see a DIY sub in the picture (hint: black tube…):
    • 3195
    WOW that sub is just HUGE
    What does it sound like? Looks like it will shake the house!!!
    • MilDoc
      And kill your hearing, like mine from listening to Doors, Cream, Iron Butterfly etc full volume in the 60s and 70s.
      • bigsteel15
        • 1079
        • Edmonton, AB
        You lucky bugger...
        That is a very nice stand Jon.
        I like the look of quality Baltic Birch when it is finished properly.
        Brian
        Welcome to the school of life
        • GeekMom
          • 752
          • Bonney Lake, WA.
          • Shopsmith Mark V
          Nice job on the stand. Sure doesn't look like a 'first project'.
          Karen
          • gerti
            • 2233
            • Minnetonka, MN, USA.
            • BT3100 "Frankensaw"
            Reminds me of a friend long ago who's room mostly consisted of a set of Klipsch horns...
            Nice work!
              Looks great. I like the look of bb although I have used it only for drawers. Maybe I should try it for the outside of something. The sub is big - how many cubic feet? I think mine is 4 - but hidden in the floor so you don't see it.
                • 10453
                Nice shelf, Jon. Simple, clean lines. Thought would be to add a 'C' shaped channel outside of the 'hooks' to partially conceal the cables.
                • Wood_workur
                  • 1914
                  • Ohio
                  • Ryobi bt3100-1
                  I like it too. I would have made a curved-ish box to house the cables, that open up with a hitten latch, but maybee that could be a later project.
                  Alex
                  • bigstick509
                    • 1227
                    • Macomb, MI, USA.
                    Nice Job
                    • JonW
                      • 116
                      Thanks for all the kind comments, folks. This is a particularly kind compliment:
                      As for the sub, I figured if I’m going to the effort to build one, it might as well be a no compromise one. Build it once and build it right, to not ever itch to upgrade. Yeah, it can play loud, but that’s not why I built it. More to play low and clean. Really nice, tight bass. For volume, it’s something like 27 cubic feet. Details here:
                      http://www.htguide.com/forum/showthread.php4?t=19517
                      For managing the cables, yeah, I thought about a few different options, including cups or C-shaped channels, hooks and clips, latches, etc. None of what I came up with seemed to work. Some of the cables are pretty stiff. And some run from one shelf to another. Some from the left side, others from the right. I didn’t want what would look like a 5th leg in the middle of the rear- it might block some cables coming out. And start tomake the whole thing look too “heavy” if there’s a lot more wood. So I settled on the hooks. They’re OK, I guess. Could certainly be improved. If you folks have any pics of alternatives, I’d be happy to see them.
                      • Jeffrey Schronce
                        • 3822
                        • York, PA, USA.
                        • 22124
                        Have you measured your Hz range? Man I bet that thing gets down there.
                          Jon, very nice job on that shelf unit. Gives me some ideas.
                          Looking at that sub, you aren't married are you? Your profile doesn't say one way or the other.
                          • Wood_workur
                            • 1914
                            • Ohio
                            • Ryobi bt3100-1
                            either of these two would work, but the first is my favorite of the two (smaller profile):
                            http://www.mmnewman.com/content/heli...plications.asp
                            http://www.mockett.com/default.asp?id=52
                            Alex
                              Looks like it might shake the neighbors house also. Very nice work on the shelves. I may use your pattern to build some.
