First Gloat!
  • Roger on the Rock
    • 88
    • St. John's, Newfoundland, Canada
    • BT-3100
    First Gloat!
    Well, here's my new BT-3100 set up in it's temporary summer home...the shed. It went together very easily and I only had to do minor adjustments to the bevel stops and rip fence. SMT was bang on right out of the box. I'm very impressed with the fit and finish of this saw as well as the setup instructions & hardware kit. Did a few test cuts and it perfomed just fine. Seems a bit slower that what I thought it would be, but it's running on about 70' of extension cord and the shop vac is on the same circuit. (I was waiting for the breaker to pop.)
    This is just the start. I'll be finishing the basement over the summer and will then move the shop downstairs. I have a basement with outside access and about 12' x 20' of good usable space...plus some overflow for material storage. After 20 years of moving around in the military, I'm very excited about settling down and being able to start into a hobby I got a taste of in high school, and that I've wanted to get back into for years.
    Thanks very much to all on this forum who provided advice on the BT-3100 and made the selection of my first major power tool a lot easier.
    Cheers,
    Roger
  • newbie2wood
    • Apr 2004
    • 453
    • NJ, USA.
    The Bt3100 is a great saw. It does require a little fine tuning but so does every table saws. The sliding rails are my favorite part of it. I have moved on to a different table saw but have no regrets about buying the Bt3100. If I had the room in my garage, I would keep the Bt3100. Enjoy and looking forward to your input on this forum.
    ________
    Avandia Class Action Lawsuit
    • Wood_workur
      • 1914
      • Ohio
      • Ryobi bt3100-1
      Looks great. Hope you have fun. Just make sure that your extension cord is the proper gauge.
      Alex
        Enjoy. And having had my saw in a glorified shed and now in my basement shop, I would say push as hard as you can to get your basement shop outfitted as quickly as possible. You won't regret it when you move your saw in that much sooner.
        • vaking
          • 1428
          • Montclair, NJ, USA.
          • Ryobi BT3100-1
          Lucky you having a basement with outside access. You probably have 8' height in that basement too.
          Seriously - congratulations with the saw. Shopvac and drill press should be next.
          Alex V
          • Roger on the Rock
            • 88
            • BT-3100
            Thanks folks.
              • 2813
              Congratulations on the new shop and the BT3K.
              I'd take steps as soon as possible to get rid of that extension cord though and get a receptacle wired within easy reach of the saw. That motor needs those amps without the loss you are probably getting in cord.
              Enjoy the new shop and the BT,
              • jcjrsmith
                • 354
                • Mechanicsburg, PA, USA.
                Congratulations!! And Paint the Red Line!!!!
                Jerry in PA
                ...Can't sleep, clown will eat me...
                http://home.comcast.net/~jcjrsmith2
