and more importantly, how do I fix it?
SMT fence drags across table. why?
First, be sure that the SMT is down tight and square to the Rails. If the Left side of the SMT is UP just a little bit, it will allow the Miter Fence to drag on the Main Table.
If you're sure everything is down and square and it still rubs, then add a piece of slippery tape under each of the 4 corners on the SMT (About 1/32" thick or less).
Usually, folks complain that the SMT is too high, but you may be the exception.Stop thinking why you can't and Start thinking how you CAN!
George
