Thanks everybody. I appreciate the replies. Glad I asked.
What rag for rubbing finishes?
That is a good idea.Originally posted by glencrosspersonally, i get all the rags i need from the local church thrift shop..they usually go for around two bucks for a full garbage bag full.
they contain old t shirts etc etc all washed and ready to use in the workshop!!
cheapest place i know of to get some rags!!Comment
Well I am finally getting around to using some wipe-on poly and was going to purchase some gloves like mentioned by Scotty but " my word! " they are expensive to be disposable. Am I reading that right - one pair for $9.00 and they're disposable? Surely not. I found some at Walmart that are made by Stanley called Nitrile disposable gloves for painting and staining for about $2.97 for a pack of 6 pairs and one pair also made by Stanley at Lowe's for about the same price but they aren't disposable. I guess the single pair would be more protection but a lot more trouble since you'd have to clean them off each time where the disposable ones would sure be handy. Anybody have any knowledge about the two?May you die and go to heaven before the Devil knows you're dead. My Best, MacComment
I just wear two pairs of the cheapest I can find. Then one one pair rips, I put on a new pair. They go for about $3 for 50, or $6 for 100.Originally posted by lcm1947Well I am finally getting around to using some wipe-on poly and was going to purchase some gloves like mentioned by Scotty but " my word! " they are expensive to be disposable. Am I reading that right - one pair for $9.00 and they're disposable? Surely not. I found some at Walmart that are made by Stanley called Nitrile disposable gloves for painting and staining for about $2.97 for a pack of 6 pairs and one pair also made by Stanley at Lowe's for about the same price but they aren't disposable. I guess the single pair would be more protection but a lot more trouble since you'd have to clean them off each time where the disposable ones would sure be handy. Anybody have any knowledge about the two?AlexComment
The MSC price is $10.25 per 100 = about 10 cents per glove for one box. The Walmart gloves come to over 24 cents per glove. I get mine from MSC also - cheaper, and much better than the Harbor Freight gloves I used to use.Originally posted by lcm1947Am I reading that right - one pair for $9.00 and they're disposable? Surely not. I found some at Walmart that are made by Stanley called Nitrile disposable gloves for painting and staining for about $2.97 for a pack of 6 pairs ...Comment
Nitrile gloves are what I use. The blue ones (only color I've seen) can be used multiple times. Pull them off from the cuff which removes them inside-out. Tuck them back outside-out and blow into the cuff to open the fingers.
HTH
kenComment
A word of warning: Any rag used to apply finishing products is a potential fire hazard! If you just crumple them up and chuck them in a bin you are asking for trouble. They have caused quite a few shop fires in Minnesota in the last months alone.Comment
Always wondered -- does this apply to water based finishes too? Oil based the reason is obvious.Originally posted by gertiA word of warning: Any rag used to apply finishing products is a potential fire hazard! If you just crumple them up and chuck them in a bin you are asking for trouble. They have caused quite a few shop fires in Minnesota in the last months alone.Comment
No its pretty darn safe.Originally posted by MilDocAlways wondered -- does this apply to water based finishes too? Oil based the reason is obvious.
The warning does apply to things you wouldn't think of like boiled linseed oil which generates heat as it dries.Comment
I've been getting the nitrile (blue) gloves at Harbor Freight. I found them at Home Depot once or twice, but the price was very high in comparison. I think HF has them on sale for about $8 or 9 for a box of 100 sometimes.
As for what is nitrile, which I think someone asked, it is just the material they are made out of. Some rubber substance with better chemical resistance than latex or vinyl.
Originally posted by lcm1947Well I am finally getting around to using some wipe-on poly and was going to purchase some gloves like mentioned by Scotty but " my word! " they are expensive to be disposable. Am I reading that right - one pair for $9.00 and they're disposable? Surely not. I found some at Walmart that are made by Stanley called Nitrile disposable gloves for painting and staining for about $2.97 for a pack of 6 pairs and one pair also made by Stanley at Lowe's for about the same price but they aren't disposable. I guess the single pair would be more protection but a lot more trouble since you'd have to clean them off each time where the disposable ones would sure be handy. Anybody have any knowledge about the two?Comment
Thanks Jziegler I thought maybe it was some kind of coating or something. That's a darn good price. I'll have to check HF out. Need some wooden clamps anyway.May you die and go to heaven before the Devil knows you're dead. My Best, MacComment
I think the HF were on sale for less than that. I am think $5-6 - 20% coupon. I have had no problems with them and have used them extensively with some pretty harsh stuff. Just don't use them or latex with stripper. I learned that bout a year ago.Comment
Ok, now I'm confused. Don't use them with stripper? Why? I would think you could use them for anything. Boy, I have a lot to learn. Glad you mentioned that little piece of info. That's why I love this forum.May you die and go to heaven before the Devil knows you're dead. My Best, MacComment
Stripper will eat holes through latex or nitrile in seconds. And it burns. Bad.Originally posted by lcm1947Ok, now I'm confused. Don't use them with stripper? Why? I would think you could use them for anything. Boy, I have a lot to learn. Glad you mentioned that little piece of info. That's why I love this forum.
You need chemical resistent gloves based upon recommendation on the can.Comment
